Activity Forums Adobe After Effects AE freez cause of fonts
  • AE freez cause of fonts
    Posted by Dotan Baytman on January 9, 2007 at 6:18 pm
    Im working on a new project and i”ve put other lenguage fonts in my windows font folder now im trying to export it as an swf file and it says
    “after effects error unable acquire font outlines”
    76 :: 64
    what is this problem? maybe its not the right way to put new fonts into AE
    is there an AE font folder?
    thanx
    Deleted User replied 19 years, 8 months ago 3 Members · 3 Replies
  • Mylenium
    January 9, 2007 at 7:23 pm
    a) Your fonts are crap and contain bad contours (free fonts often do this).
    b) One of your fonts is damaged.
    c) Your Windows System is not correctly configured to handle foreign fonts. General language settings do matter since e.g. Asian fonts use different encodings.
    d) For Asian fonts you may even need to install AE in Japanese.
    Check all the above. Either one or a combination of multiple problems might cause your trouble.
    Mylenium
    [Pour Myl
  • Dotan Baytman
    January 9, 2007 at 7:25 pm
    IM using AMD dual core
    im using windows xp and AE 6.5 pro
    i can see the fonts in my comps but it freez only when i export to swf
    and its a banner for the web
  • Deleted User
    January 10, 2007 at 2:45 am
    Hello,
    Likely to be a bad font, if you need to install languages, you the XP CD and go to control panel, they languages. You can then install the language you need.
    I did this for Chinese texts, and it worked perfectly. I am running XP PRO with SP2 English.
    Leo
