Activity Forums Adobe After Effects AE for TV production
  • AE for TV production
    Posted by Daniel Unkenholz on July 20, 2007 at 10:39 pm
    how can i find out what paramiters my AE needs to be set at for tv production. I will be using AE for every tv spot I edit I dont want my whites and reds to be blown out on my vector scopes, is there a way to set up AE so I can use it for this purpose without having to redo my wht’s and red’s with every new project I do? thx and love ur site.
    Dan Asselin replied 19 years, 2 months ago 4 Members · 3 Replies
  • Steve Roberts
    July 21, 2007 at 2:11 am
    You can’t do it in prefs – you have to do it on a comp-by-comp basis. But it’s easy. You should set up a preset effect using levels and hue/sat, then apply it to an adjustment layer over the comp. After you’ve set it up once, for each comp to render, it’s:
    1) layer>new adjustment layer
    2) animation>apply effect preset.
    Two clicks.
    BTW, levels should generally be 16-235, and your reds should be desaturated, with your yellows moved a little toward orange. You should run a couple of tests by your scopes (at the end of the workflow) before you finalize the preset.
    Anybody else?
  • Scott Roberts
    July 21, 2007 at 3:09 am
    I agree with that, and make sure to view your work through an NTSC monitor. You’ll be amazed at the difference of working in AE on a CRT and how your work appears on a calibrated monitor . . . in addition to live and action areas and how your titles and graphics fit. I can’t stress enough the importance of having your work viewed on a monitor.
    Also, make sure your comp dimensions are correct for broadcast.
    Good luck.
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
  • Dan Asselin
    July 22, 2007 at 6:20 pm
    If you check out the archive Aharon created an awesome tutorial for setting AE outout to broadcast specs.
    Dan
