Activity Forums Adobe After Effects AE, FCP, & compression (for HD 15-min short animated film)
  • AE, FCP, & compression (for HD 15-min short animated film)
    Posted by Mardo El-noor on March 17, 2008 at 2:53 am
    hi everyone… here’s the situation:
    a short film, 150 shots (total of 15 minutes) of 1080 X 1920 of AE (CS3) sessions (shots are made of HD footage, animation, motion graphics) on Win XP (3.4GHz processor & 2GB of RAM)… editing machine is Mac (2X2.66GHz processor with 4GB of RAM) using FCP 5.1.4 with 500GB external HD…
    how can i edit a full resolution renders of these shots as the Mac can’t handle the load?? where is the best place to apply compression???
    i need the highest quality as the short film is aimed for submitting to film festivals…
    any ideas are much appreciated…
    Mardo El-Noor
    Freelance Animator
    auckland, New Zealand
    Mardo El-noor replied 18 years, 5 months ago 3 Members · 4 Replies
  • Darby Edelen
    March 17, 2008 at 4:26 am
    [Mardo El-noor] “how can i edit a full resolution renders of these shots as the Mac can’t handle the load?? where is the best place to apply compression???”
    What do you mean the Mac can’t handle the load? We regularly edit 1920×1080 HD material in Final Cut Pro. You may need to change your sequence settings to match the AE renders, otherwise you will constantly be forced to render in FCP to conform the footage to the sequence settings.
    I wouldn’t compress anything until the very end when you need to create the deliverable (and if you’re delivering on a hard drive, don’t even compress it then!). You may need to find out exactly what the film festivals will require.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Mardo El-noor
    March 17, 2008 at 4:47 am
    thanks for replying…
    i failed to mention that the ONLY uncompressed 1080X1920 full res render i can get from AE current settings is 9.2GB a minute… in AE, all shots have 10 to 50 photoshop layers, some HD video footage, & some have light effects…
    thanks
    Mardo El-Noor
    Freelance Animator
  • Steve Roberts
    March 17, 2008 at 1:26 pm
    Sorry, but you’re not telling us what the problem is.
    Is the computer crashing? When?
    Are you running out of hard drive space?
    Is rendering too slow and you’ll miss the deadline?
    Let us know.
  • Mardo El-noor
    March 18, 2008 at 7:21 am
    i should’ve been a bit clearer…
    with files of this size (9GB/min), i can’t view them on QT (it stops, becomes jittery, or it crashes, even on the MAc with the aforementioned specs)… it takes a very long time to do ANYTHING with them in FCP… & yes, the Mac computer crashes occasionally..
    thanks a lot
    Mardo El-Noor
    Freelance Animator
