Activity Forums Adobe After Effects AE Error: crash occured while invoking rendering plug-in “Open GL
  • AE Error: crash occured while invoking rendering plug-in “Open GL
    Posted by Ryan Armstrong on November 5, 2009 at 10:00 pm
    i need help on this because i dont know what to do about it happens when i click on the play button it works fine until i click any thing else then it crashes
    Hope Holmesby replied 11 years, 9 months ago 4 Members · 3 Replies
  • Andy George
    November 5, 2009 at 10:44 pm
    Try switching to adaptive resolution. At the bottom of your comp
    preview is a little icon that looks like a lightening bolt and says
    “fast preview” when you hover over it. Click this and select adaptive resolution.
    or you can do this from the menu:
    After effects>preferences>preview
    -Andy
  • Sumit Mehta
    November 7, 2009 at 10:17 am
    Open GL sucks for rendering.
    i had this problem rendering one of my projects a few months back, just deleted my OpenGL plugin and i was back in business
    you can usually find it at
    (whereever your AE is installed) > support files > Plug – ins > Extentions
    try Deleting the OPenGL plugin from there and see if it makes any difference
    good luck =]
  • Hope Holmesby
    December 3, 2014 at 5:57 am
    Sumit
    that deleting the plugin worked for me
    after installing mavericks, in AE, color balance plugin is not working…keeps crashing…with the message that it is the opengl that is the problem. didnt even have it checked to use in the preferences…it was off, but still causing the problem.
    BUT your suggestion to delete the plugin WORKED!!!
    Now color balance is working. hurray
    Thanks so much
    __________________________________________________
    Life is here to enjoy.
    iMac 3.5 GHz Intel Core i7, 2TB;
    Mac OS 10.9,
    16 GB RAM;
    2 La Cie external HDs 1 TB each;
    After Effects CS5.5;
    Sound Track Pro 3.0.1;
    Final Cut Pro 7.0.3;
    Compressor 3.5.3
