Activity › Forums › Adobe After Effects › AE Duik Plugin Error
  • AE Duik Plugin Error
    Posted by Hana Kim on September 5, 2013 at 7:59 pm
    Hello,
    I am working with Duik plugin for After Effect and it is suddenly giving me an error which it never gave me before.
    It keeps saying..
    invalid numeric result(divided by zero?) expression disabled.
    I am not expert on coding- Found this lines. But not sure what’s the problem. The message says error is on the line 23… I looked into the same error message in this forum, but cannot figure out how to apply the answers to this specific Duik problem. Any thought/insight will be appreciated.
    boneracine = “2_L_rear_leg”;
    bonebout = “2_L_rear_foot”;
    zero = “IK_zero 2_L_rear_foot”;
    controleur = “C_2_L_rear_foot”;
    if (thisComp.layer(controleur).effect(“IK Orientation2_L_rear_leg”)(1) == 1) {cw = true}else{cw=false}
    function getWorldPos(theLayerName){
    L = thisComp.layer(theLayerName);
    return L.toWorld(L.anchorPoint);
    function oriente(a, b, P) {
    return ((b[0]-a[0])*(P[1]-a[1]) – (P[0]-a[0])*(b[1]-a[1]) );
    A = getWorldPos(boneracine);
    B = getWorldPos(bonebout);
    C = getWorldPos(zero);
    E = getWorldPos(controleur);
    a = length(B,C);
    b = length(E,A);
    c = length(A,B);
    x = (b*b + c*c – a*a )/(2*b);
    alpha = Math.acos(clamp(x/c,-1,1));
    y = b – x;
    gamma = Math.acos(clamp(y/a,-1,1));
    result = (cw ? 1 : -1)*radiansToDegrees(gamma + alpha); V1 = B – A;
    adj1 = radiansToDegrees(Math.atan2(V1[1],V1[0]));
    V2 = C – B;
    adj2 = radiansToDegrees(Math.atan2(V2[1],V2[0]));
    result + adj1 – adj2 + value;
    Joe Presser replied 11 years, 3 months ago 4 Members · 3 Replies
  • Mike Roberts
    September 12, 2013 at 2:50 pm
    I get these errors sometimes. Without having more info – Have you tried deleting all the relevant expressions and re-doing the IK? That is probably easier than troubleshooting.
  • Kevin Prange
    March 24, 2014 at 9:36 pm
    Hana, did you ever solve this problem? I am getting it every time I try it. I was able to make it work several months ago, but not now.
    Kevin Prange
    NAED, St. Louis, MO
  • Joe Presser
    June 13, 2015 at 5:35 pm
    Just to anyone looking to fix this, I just had this error. I think it comes from when an anchor point of a bone isn’t touching part of the parent.
