AE dome screen motion graphics
A client wants me to make a specific animation for a very different venue: a planetarium. You know, a dome screen with multiple projectors. So my question is one of effects, then of workflow.
First, effect. The desired result is to have the camera flying through the tops of the clouds towards the setting sun. Here is the rough concept:
The photo shows the dome from below. The bottom of the pic is the front of the planetarium theatre. I want the camera flying through the tops of the clouds towards the setting sun with empty sky above. This is easy with a camera looking in one direction, but not so straightforward when viewing a 180 degree dome..
I have read much about making a 180 degree lens in AE, but I have also heard of very expensive softwares and plugins that will do it, so I’m not so sure the simple 180 degree AE camera lens will work. I’ve also heard talk of using CC Sphere, but no one has ever explained how that would actually work…
I have an idea to make 4 or 5 cameras, one pointing in every direction, each pointing up at about a 45ish degree angle, so that the clouds are at the bottom, empty sky on top (possibly one pointing up). Then I would take the 4 (5) comps I would make out of that and warp, distort, and stitch them together to make one video. The final result of which will look similar to my example pic above.
My question is, is that even possible? I mean, there’s pricey software that does that… is AE capable of doing so? if so, how?
To put it more simply, I have no idea how to create motion graphics for a dome screen. What do i do, without a budget for new plugins and software, using AE CS5?
