Activity › Forums › Adobe After Effects › AE dome screen motion graphics
  • Jesse Brady
    April 29, 2015 at 1:53 pm
    We’ve been in the middle of a big Planetarium Dome project right now actually. We’ve been using several strategies that have been really effective.
    There are Stitcher apps that can take 5 images (top, left, right, front, back) and fuse them together into a circular image that can be displayed on the dome correctly. If you set up five cameras in at the same point in space, rotated 90 degrees from each other with a 90 degree view angle, creating a perfect box of camera view, the cameras will record all the information around them in a way that the stitcher can interpret correctly. You would render out 5 image sequences, and stitch the matching frames together…not as bad as it sounds…get yourself a free batch-renaming app to handle renaming lots of files at once to simplify things.
    This will be perfect for recording animations that surround the viewer, but if you have a flat, video that you want to wrap around the dome…that could be trickier. Here’s some tips though:
    Use the Affter effects “Polar Coordinates” effect to “unwrap” or “Wrap” the video or image in a circular way. This will not be perfect…particularly for the top areas of the dome…but there are planetarium dome templates that show a circular grid which corresponds to locations on the dome screen, download one and use it as a guide to finesse your distortion… We actually have an After Effects comp set up that unfolds circular video from the dome using Polar Coordinates…we can use it to create graphics displayed right in front of the viewer with very little distortion (graphics toward the top of the dome are tougher this way)…in the main comp, the polar coordinates effect is not active, so it just bends the footage back into a circle.
    …or you could try projecting your video onto an actual 3D Dome and using the 5 camera method to capture it…this could be a more exact approach, but I haven’t tested it.
  • Tim Parsons
    April 29, 2015 at 2:53 pm
    Jesse, care to elaborate on some of the effects and their parameters? perhaps screen grabs?
  • Tudor “ted” jelescu
    April 29, 2015 at 6:56 pm
    If Chris Bobotis can pitch in maybe he can give you some details on a new Mettle plugin that can possibly work like a charm for projects like this.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Chris Bobotis
    April 29, 2015 at 7:11 pm
    Pictures are better than words 😉
    Please see: https://www.mettle.com/mettle-skybox-sneek-peek-free-sample/
    Feel free to reach out to me at chris at mettle dot com
    We are launching this very soon. Instructional videos etc. in the works.
    This is great for use with all 3D plugins that support reflection mapping and environment mapping. we create Cubic, Spherical and Equirectangular formats.
    I can see Mettle SkyBox output used with all 3D plugins that support reflection mapping or environment or for use with 3D apps like C4D Maya etc. Game engine like the Unreal engine, Unity 3D… webGL… Dome projections or for VR.
    Ae plugins like FreeFormn Pro, ShapeShifter, Element 3D, Zaxwerks, Boris 3D should benefit from this offering.
    Cheers,
    Chris
    mettle.com
Page 2 of 2
