Activity Forums Adobe After Effects AE digital signage / Vertical Plasma
  • AE digital signage / Vertical Plasma
    Posted by Kevin Candela on May 3, 2012 at 12:29 am
    Greetings friends.
    I have a 1920×1080 HD plasma that will feature digital signage. Motion Graphics. No video. The plasma will be turned vertically and mounted to a wall. I will probably lay it out in photoshop vertically, and bring in the art as layers into AE. Working vertically in AE, what is the best way to rotate it after the design is complete. What would be the best approach to this?
    Thanks. Kind regards. K
    Bill Chennault replied 14 years, 2 months ago 3 Members · 3 Replies
  • John Cuevas
    May 3, 2012 at 1:18 am
    Work in your comp 1080 x 1920(Comp_Vert) and when you are finished create a new 1920×1080 Comp_Horz and drag Comp_Vert into it. Now just rotate 90 degrees. Now you can send it to your encoder, DVD/Blu-Ray, hook it up to the tv and it’s good to go.
    Just make sure to know how the tv’s going to be mounted, 90 degrees Clockwise or CounterClockwise and you should be fine.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Kevin Candela
    May 4, 2012 at 12:34 am
    Thanks John!
  • Bill Chennault
    July 5, 2012 at 9:43 pm
    Easy work bro. If you truly are setting it up in photoshop to the vertical aspect ratio then set it up in after effects exactly the same way. THEN create a new composition with the vertical aspect dimension size. THEN drop the comp you created horizontally into the new vertical aspect ratio comp. THEN rotate it 90 degrees…. I do this all the time.. easy work.
