AE CS6 Render Artifacts
I am working in AE CS6 using image sequence as footage. I often need to render/re-render portions of it. Lately, some artifacts started to appear on the rendered images, namely — a nasty horizontal punctured line, white or black, across the image. It looks exactly as if someone scratched a photograph with a pin. These artifacts appeared before as well, but only in RAM preview and won’t appear in the final render. Now they appear embedded in the final render.
What gives?
