Activity Forums Adobe After Effects AE CS6 Multi Processiong is a dissappointment
  • AE CS6 Multi Processiong is a dissappointment
    Posted by Tom Daigon on February 8, 2013 at 2:12 am
    Its a shame that whenever I try to use MP on my Z820, it never seems to work. Very disappointing. Im getting used to ignoring it.
    I have a very simple comp consisting of 1 layer of Element 3D (which contains a OBJ sequence of simple domino shaped 3D models.)
    Then there is a floor layer, a light and a camera.
    I am using Elementary on the Element layer to create artificial shadows of the line of domino objects on the floor
    I have 2- 2687 processors with 32 hyper threads and 64 GB of ram all dedicated to AE.
    When I start the render it sits there for five minutes telling me its doing 2 out of 250 frames. No progress is seen on the timeline. I just stop it at this point since regular rendering seems faster.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
    Tom Daigon replied 13 years, 7 months ago 3 Members · 5 Replies
  • Todd Kopriva
    February 8, 2013 at 2:55 am
    Element 3D is not compatible with the Render Multiple Frames Simultaneously multiprocessing feature. That feature relies on using multiple CPUs, each rendering a separate frame. That model doesn’t work when a plug-in like Element 3D relies on the single GPU.
    After Effects team blog
  • Tom Daigon
    February 8, 2013 at 2:57 am
    Thank you Todd. That would explain my difficulty with it. No more MP for Element projects.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
  • Roland R. kahlenberg
    February 8, 2013 at 3:31 am
    Tom, you may want to look at using the Spacebar for non-RMFS situations. This precludes having to jump in/out of the Prefs DIalog Window.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Todd Kopriva
    February 8, 2013 at 4:08 am
    BTW, the same goes for other GPU-dependent things, like the ray-traced 3D renderer.
  • Tom Daigon
    February 8, 2013 at 5:31 am
    Thanks for the info everybody.
    Todds clarification of the MP functions addressed the issue at hand.
    Things running quite well.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
