Activity Forums Adobe After Effects AE CS6 – Incompatible Preview Mode: Multiprocessing Disabled
  • AE CS6 – Incompatible Preview Mode: Multiprocessing Disabled
    Posted by Scott Green on April 7, 2013 at 10:41 pm
    I’ve recently upgraded to a 12 core Mac Pro, put a 512GB SSD in it and have 28GB of RAM.
    However, when I’m previewing my project I get a message saying “Incompatible Preview Mode: Multiprocessing Disabled”
    How can I resolve this?
    Here are my multiprocessing setting for reference also:
    Thank you in advance.
    Creative Multimedia Design Manchester | S©tt Green | Splurj
    Alex Gerulaitis replied 13 years, 2 months ago 4 Members · 13 Replies
  • 13 Replies
  • Todd Kopriva
    April 7, 2013 at 11:59 pm
    If you’re using a preview mode that uses the GPU, then Render Multiple Frames Simultaneously multiprocessing is temporarily disabled. That feature is made for spreading renders out over several CPUs, so it doesn’t make sense for GPU rendering.
    After Effects team blog
  • Scott Green
    April 8, 2013 at 8:14 am
    Will my GPU (ATI Radeon HD 5770 with 1GB of GDDR5 memory, PCI Express 2.0) not work with multiprocessing?
    If I turn off multiprocessing am I not using OpenGL either?
  • Todd Kopriva
    April 8, 2013 at 2:26 pm
    This has nothing to do with specific GPUs. What I said applies to all graphics cards.
  • Scott Green
    April 8, 2013 at 3:26 pm
    Where do I see if I’m using the CPU or the GPU?
    To me it looks like I’m using the CPU because when I click Preferences > Previews > GPU Information, next to Ray-tracing CPU is selected with (GPU not available – incompatible device or CUDA driver) next to it.
    I can’t select ‘GPU’ from the list either?
    This is a confusing subject!
  • Todd Kopriva
    April 8, 2013 at 3:56 pm
    Here are details of how the GPU is used in After Effects:
    https://blogs.adobe.com/aftereffects/2012/05/gpu-cuda-opengl-features-in-after-effects-cs6.html
  • Steve Martin
    June 14, 2013 at 2:56 am
    Sounds like you need to go to the NVIDIA website and download the CUDA driver
  • Scott Green
    June 14, 2013 at 7:02 am
    My Mac Pro has a ATI Radeon HD 5770 GPU installed in it, I’m guessing that an Nvidia driver won’t benefit me whatsoever?
    Could you recommend an affordable Nvidia GPU that I should consider upgrading to in the future?
    Thanks for your reply.
  • Alex Gerulaitis
    June 14, 2013 at 7:29 am
    [Scott Green] “Could you recommend an affordable Nvidia GPU that I should consider upgrading to in the future?”
    GeForce GTX-680 Mac Edition has the best power-to-cost ratio. 2nd choice – Quadro 4000 Mac (on ebay).
  • Steve Martin
    June 14, 2013 at 8:45 pm
  • Scott Green
    June 14, 2013 at 8:50 pm
    Thanks very much.
    That list of products doesn’t show the GeForce GTX 680 as being supported by Mac as mentioned by Alex though, is that correct?
