Activity › Forums › Adobe After Effects › AE CS6 – Incompatible Preview Mode: Multiprocessing Disabled
Alex Gerulaitis replied 13 years, 2 months ago 4 Members · 13 Replies
Steve Martin
June 14, 2013 at 8:55 pmThat list is for Adobe CC
CS6 will differ. There is a way to “trick” After Effects into recognizing other than supported cards.
https://www.vidmuze.com/how-to-enable-gpu-cuda-in-adobe-cs6-for-mac/
Neat trick 😉
Scott Green
July 3, 2013 at 2:23 pmCan anyone confirm that the Nvidia Quadro 4000 for Mac will support the 27″ LED Cinema Display that I’m using with my MacPro?
The GPU spec says it has a ‘DISPLAYPORT’ connection but Apple call the connection on the Cinema Display a ‘MINI DISPLAYPORT’, are they the same thing or not?
If you are 100% sure please let me know. I bought a Thunderbolt Display once because someone told me it had the same connection as my MacPro but it turned out that Thunderbolt and Mini Displayport are different although they look the same and both fit, and I don’t want to do the same thing again.
Thank you 🙂
https://www.nvidia.com/object/product-quadro-4000-mac-us.html
Creative Multimedia Design Manchester | S©tt Green | Splurj
Alex Gerulaitis
July 3, 2013 at 4:30 pm[Scott Green] “Can anyone confirm that the Nvidia Quadro 4000 for Mac will support the 27″ LED Cinema Display that I’m using with my MacPro?”
It does with an adapter, a “DisplayPort to mini-DisplayPort cable” that is included with the PNY version (which I think is the only version out there).
See also this related discussion.
Alex Gerulaitis
Systems Engineer
DV411 – Los Angeles, CA
