Activity Forums Adobe After Effects AE CS6 crash <0> Vid rate ratios miin, max: 1, 1
  • AE CS6 crash <0> Vid rate ratios miin, max: 1, 1
    Posted by Diogo Mendes-pinto on March 25, 2015 at 12:22 pm
    I’m trying to render a comp in AE CS6 11.0.0.378 witch among some normal effects has Element 3d 1.6.0 and Optical Flares 1.2.132 with GPU off.
    Whenever I try to render I get this crash error:
    Last log message was: <140735077280960> <0> Vid rate ratios min, max: 1, 1
    myleniumerrors.com says: “There was an issue with the audio in your footage and it caused an encoding failure.” But I don’t have a single layer or file with sound in it.
    Can some one help me please?
    I’m on a late 2009 iMac 27′ i7 2,8GHz, 8GB RAM, ATI Radeon HD 4850 512MB
    Diogo Mendes-pinto replied 11 years, 5 months ago 2 Members · 2 Replies
  • Todd Kopriva
    March 26, 2015 at 12:00 am
    To begin with, install the most recent update for After Effects CS6; you are four bug-fix updates behind:
    https://adobe.ly/DVA_updates
    After Effects product manager and curmudgeon
    After Effects team blog
  • Diogo Mendes-pinto
    March 26, 2015 at 11:37 am
    Thank you for your reply!
    I was thinking to do that but only after I finish this project.
    I managed to isolate the problem with the Element3D Layers witch I now rendered in a different comp.
    By the way I pasted the error wrong. The error is : Last log message was: <140735077280960> <0> Vid rate ratios min, max: 1, 1
