Activity › Forums › Adobe After Effects › AE CS6 Adjustment Layer unstable
  • AE CS6 Adjustment Layer unstable
    Posted by Steve Guluk on November 28, 2012 at 4:30 pm
    Hello,
    I have an AE Compositing consisting of (bottom up order: ) Sound file (WAV), HD mpeg, a Photoshop file (matt painted to add corrections to underlying mpeg, masked to show only the areas where action happens) and finally on top an Adjustment Layer used to color enhance/correct both the Photoshop matt and mpeg movie.
    The problem is that te effect layer does not seem to hold a fixed value as the movie is scrubbed as well as in rendered form. There are flashes of color and desaturation.
    Without the Adjustment Layer the movie and it’s matt layer hold true when scrubbed or rendered.
    Why does the adjustment layer not remain consistent?
    I’ve tried Auto Color and Auto Contrast effects applied to the Adjustment Layer
    Thinking that these “auto” versions may be dynamically adjusting, I removed them and added Color Stabilizer and Levels as effects. Same problem.
    Next steps are to try to recreate the matt image overlay in Premiere and if that fails pre-render the layers in AE and apply the effects to the combined result from the pre-render.
    Is there a know problem using an Adjustment Layer?
    Todd Kopriva replied 12 years, 9 months ago 2 Members · 4 Replies
  • Todd Kopriva
    November 28, 2012 at 8:55 pm
    I don’t think that the fact that you’re using an adjustment layer is the cause of what you’re seeing.
    The effects that you’ve applied (including Color Stabilizer) cause the color values of the layer to change based on the content of the layer, so it’s expected that you’d see fluctuations in color if you hadn’t set the effects up correctly.
    After Effects team blog
  • Steve Guluk
    November 28, 2012 at 9:59 pm
    Problem was solved by prerendering out the matt layer and video then applying the 2 effects directly to the reimported layer.
    But to re-test I went back to the Composition and found no problems. The problem was dramatic as shown from this test render:
    https://sgdesign.com/tmp/comp/
    Since the prior problematic comp no longer shows the same results, I think it was a bug and restarting the App seems to have fixed it.
  • Steve Guluk
    November 28, 2012 at 10:03 pm
  • Todd Kopriva
    December 14, 2013 at 8:06 pm
    The After Effects CC (12.2) update fixes a cause of a crash involving the Auto Contrast effect, Auto Levels effect, and other related effects.
    Let us know how it works for you after you’ve installed the update.
