Activity Forums Adobe After Effects AE CS5.5 stereo audio becomes dual mono in FCP
  • AE CS5.5 stereo audio becomes dual mono in FCP
    Posted by Jan Van den bossche on February 14, 2012 at 1:43 pm
    working in CS5.5 on a MacPro.
    I render a comp with a stereo audio file to a QT Movie with any codec, settings are stereo 16bit, the audio output mapping is set to Left:Out1 Right:Out2 Then I import this movie file in FCP7. There it shows up as 2 mono channels.
    If I play the QT Movie in QT Player or MPEGstreamclip the “info” windows say it’s “stereo”.
    Very strange…
    Where did I go wrong?
    Jan
    Jan Van den Bossche
    Jan Van den Bossche
    Jan Van den bossche replied 14 years, 6 months ago 3 Members · 5 Replies
  • John Cuevas
    February 14, 2012 at 2:02 pm
    The left and right channels are just being seperated in FCP, you have stereo. Left Mono + Right Mono = Stereo
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jan Van den bossche
    February 15, 2012 at 8:30 am
    thanks for your answers.
    Of course I don’t edit audio in AE, that wouldn’t be smart.
    But I make 30″ commercials, I get 30″ stereo mixed and finalized audio wave files from the audio production studio.
    So I render the final commercial from AE to deliver for broadcasting. If I import that final QT Movie to double check it in FCP then it says dual mono. It’s not a disaster but it’s strange since that it isn’t the case in CS4 and I checked all settings.
    Dual mono isn’t the same as stereo. You still have to “pan left and right” to get a stereo sound.
    Jan
    Jan Van den Bossche
  • Erik Lindahl
    February 15, 2012 at 9:44 am
    I’ve had this problem since After Effects CS5 and onwards and haven’t found a solution. I have to manually link up the dual mono to a stereo pair in FCP which is a pain (and it’s happened others have missed this and actually delivered dual mono spots to TV).
    A solution would be appreciated.
  • Erik Lindahl
    February 16, 2012 at 12:19 pm
    Then change your workflow. Bring video and audio together in a video editing application, where the audio will behave properly and export properly.
    That’s a somewhat backwards way of thinking. This is an obvious bug in After Effects, QuickTime or Final Cut Pro – I’d say in how AE writes the QT-file or how FCP interoperates what AE writes to the QT-file.
    Yes, you can solve it by using another approach (linking mono-tracks to stereo in FCP and rendering out a new file) given that takes time and shouldn’t be required.
    I’d recommend people seeing this bug to submit a report to Adobe so they fix it.
    February 16, 2012 at 12:30 pm
    Thank you Erik, I totally agree.
    let’s hope someone at Adobe looks into this.
