Activity Forums Adobe After Effects AE CS5.5 squishes image mx02LE w/max
  • AE CS5.5 squishes image mx02LE w/max
    Posted by Eric Santos on September 15, 2011 at 1:01 am
    My footage is squished on the external monitor, it’s taller and I have black bars on the left & right sides.
    The footage was shot on a hvx200 1080Pa24 and It looks fine in FCP.
    I have updated MX02 to 2.2.3.0043 and the associated firmware upgrade
    I am running 10.6.7 on a MBP 4GB
    Fresh install of CS5.5 Production Premium
    Any suggestions?
    Regards
    Eric
    Eric Santos replied 14 years, 11 months ago 2 Members · 5 Replies
  • Roland R. kahlenberg
    September 15, 2011 at 5:58 am
    It’s likely a footage interpretation issue between AE and the source aspect ratio (pixel and resolution aspect ratios). What are the specs of the 1080P coming from the camera?
    Cheers
    RoRK
    Intensive AE & Mocha Training in Asia.
  • Eric Santos
    September 15, 2011 at 2:54 pm
    @RoRK, It does look fine in the timeline viewer, just the external output of the MX02 is squished, dod you still think it’s a ootage interpretation issue?
    The footage is 1280 * 1080, 1.5PAR, DVCPRO 100 1080pa24
    Regards
    _Eric
  • Eric Santos
    September 15, 2011 at 3:51 pm
    @Dave, the footage looks correctly in the comp window & pixel aspect ratio compensation has no effect on the external image but does in the comp window.
    Regards
    _Eric
  • Eric Santos
    September 15, 2011 at 4:08 pm
    @Dave, yes I have updated the driver/firmware and al talking with Matrox support, just hoping someone here had the same issues with the comp window not matching the ext monitor
    Regards
    _Eric
  • Eric Santos
    September 15, 2011 at 9:23 pm
    This is now a known issue that Matrox support has duplicated and investigating.
    Regards
    _Eric
