Activity Forums AJA Video Systems AE CS4, Kona 3 and Half Res RAM Preview.
  • AE CS4, Kona 3 and Half Res RAM Preview.
    Posted by Jean-michel Boublil on December 27, 2009 at 7:18 pm
    I am having a very annoying problem trying to RAM preview in AE CS4 at half res/50% and below.
    My system configuration is
    MacPro 2008, 16GB RAM, 8800GT.
    I am running AE 9.02 on 10.5.7 and am not using the AJA CS4 utilities as they create some problems on my workstation, AJA Kona3 driver v7.1
    I am outputting and HD SDI signal to HD SDI monitor, with the AE preference video preview selected on AJAKona 1080i25 RGBA. (Full HD comp of course) While at Full/100% everything is working in Realtime and I have my full HD preview running on my monitor, as soon as I choose to preview in Half Res and 50% size, everything runs at 6-8 fps. IT IS IMPOSSIBLE TO WORK LIKE THIS! and is very frustrating.
    In a comp which is standard PAL all works fine in Full/Half/Quarter etc…
    My AJA control panel output1 is set to 1080i and the secondary output to 625i and is connected to an SD monitor in order to have both HD and SD monitoring but this should not be a problem….
    I am desperately looking for a solution for that and any help will be appreciated.
    ThanX in advance and happy holiday season to all.
    jm.
    Jean-michel Boublil replied 16 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
