Activity Forums Adobe After Effects AE CS4 crash on startup with OSX Leopard
  • AE CS4 crash on startup with OSX Leopard
    Posted by Alisdair Jones on February 21, 2009 at 1:15 am
    Just installed CS4 Production Premium on my new MacBook Pro 17″ ( new uni-body model ), OS X 10.5.6. When I launch After Effects, it bounces once or twice in the dock and that’s it. I’ve updated all of the Adobe CS4 components to their latest versions. I’ve also tried dragging the AE_OpenGL.plugin from the Extensions folder, but that doesn’t change anything.
    Photoshop, Illustrator, Premiere and Bridge all launch as expected.
    Thoughts?
    Alisdair Jones replied 17 years, 2 months ago 3 Members · 4 Replies
  • Kevin Camp
    February 21, 2009 at 1:52 am
    try to repair permissions (applications/utilities/disk utility, click the repair permissions button).
    if that doesn’t help, remove the entire ae preference folder. should be in users/username/library/preferences/adobe/after effects, it’s should be called ‘9.0’. just move that to the desktop and then see if ae will start.
    if not, try creating a new user account, switch to that and see if you can open ae. if so then there is something bad with your other user account.. it can be hard to track those issues down, you might just use the new user account or call adobe support.
    if it doens’t help, then you know something is wrong with the install… you can try to re-install (try a safe boot, then install, check the apple help for safe boot instructions) or call adobe support. it’s free for installation issues…
    the only other thing i can think of (but your crash doesn’t sound like this issue) is bad quicktime components (codecs). if you want to rule those out, go to the library/quick time folder and users/username/library/quick time folder (not the system/library quicktime folder) and move all the contents to a folder on your desktop (or some place outside the library folder).
    old third party codecs can make ae crash, butit usually gets further along in the start up… if that helps, try to find the latest versions of those qt components and install those.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Alisdair Jones
    February 21, 2009 at 3:35 am
    Many thanks for the suggestions Kevin, I’ll give them a shot in the morning,
    cheers, Alisdair
  • Greg Knowles
    June 29, 2009 at 5:24 am
    I recently had a similar problem running AE CS4 9.0.2 on a Mac running OS X 10.5.7.
    What I discovered was that three files in my Library/QuickTime folder were crashing AE on start up. These files were:
    Flip4Mac WMV Advanced.component
    Flip4Mac WMV Export.component
    Flip4Mac WMV Import.component
    After I discovered this, I went to the Flip4Mac website (https://www.telestream.net/flip4mac-wmv/overview.htm) and downloaded the latest free version of the program. After I installed that, AE started up fine.
    Hope this helps!
  • Alisdair Jones
    June 29, 2009 at 1:23 pm
    Interesting … I tried repairing disk permissions, but that didn’t work. I eventually created a new admin account and that did it.
