Activity Forums Adobe After Effects AE CS3 Slow to start rendering
  • AE CS3 Slow to start rendering
    Posted by Gary Childress on February 25, 2009 at 9:31 pm
    I am having real trouble with preview and output renders in CS3 where
    it “thinks” for almost 5 min. before it starts a ram preview or final render out. It’s not that complicated a piece but uses Keylight 1.2v5
    on several layers.
    No problem scrubbing the timeline, it’s only when you preview or render.
    I have gotten several warning messages basically it can’t initiate Keylight but it doesn’t do that every time I try to
    preview or render. The footage being keyed it coming from an Avid.
    It’s Standard Def 1:1 10 bit.
    It was working fine yesterday but today is a different story. Have already tried restarting.
    Machine specs:
    Octo Mac
    10 gig ram
    Gary Childress replied 17 years, 7 months ago 2 Members · 2 Replies
  • Kevin Camp
    February 25, 2009 at 10:39 pm
    there is an update (actually 2 since 1.2.5), you can find it here:
    https://www.thefoundry.co.uk/pkg_downloads.aspx?ui=A5FB8E97-D752-4E01-AC7D-17B39B7E1192
    it may fix the problem… i’ve been using v1.2.8 since getting cs3 and i haven’t seen what you’ve described.
    you could also try disabling ae’s multiprocessing (‘render multiple frame simultaneously’). keylight is natively multithreaded, though i have not tested it’s performance vs. ae’s.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Gary Childress
    February 25, 2009 at 11:50 pm
    Thanks for getting back to me guys.
    Dave,OpenGL was on but turning it off didn’t fix the problem.
    Kevin, multiprocessing was already off.
    Oddly, it seems to be a corrupt comp. I started a new comp and then pasted the layers one by one into it to try to isolate a bad layer.
    As it turned out, I pasted all the layers from the old comp to the new
    and it works fine now. The old comp still hangs but the new one works
    normally. I didn’t know you could get a bad comp but there you go.
