Activity › Forums › Adobe After Effects › AE CS3 Public Preview update!
  • AE CS3 Public Preview update!
    Posted by Adolfo Rozenfeld on May 18, 2007 at 5:25 pm
    Hi, guys!
    As many of you were requesting, here’s an update for Public Preview, so you don’t have to wait for the final product to see some issues solved.
    It includes many fixes, especially for the Quicktime-related issues some of you were experiencing. Let me know if this is the cure or not for you 🙂
    Please throw any Quicktime-Animation file you have at it!
    You can get it here:
    https://www.adobe.com/cfusion/entitlement/index.cfm?e=labs_aecs3preview
    Please, please, please remember to use the uninstaller before installing this new build. I mean it!
    On Macs, it’s located in Applications > Utilities > Adobe Installers.
    On Win, use the Add/Remove Programs control panel and follow the on-screen instructions.
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    ar(AT)adolforozenfeld.com
    Solie Swan replied 19 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Ronaldo Montalvo
    May 18, 2007 at 6:05 pm
    that’s great. if you already have a beta preview serial number from an installed version of AFX CS3 do you need to get a new beta serial number to go behind the 2 day trial or will the same one work?
  • Adolfo Rozenfeld
    May 18, 2007 at 6:07 pm
    The same one should work.
    Adolfo Rozenfeld
  • Solie Swan
    May 21, 2007 at 12:46 am
    After uninstalling After Effects CS3 (on windows) and running the new installer I get a message saying: Adobe After Effects CS3 cannot be installed because it conflicts with:
    * Adobe After Effets CS3
    Any suggestions?
  • Adolfo Rozenfeld
    May 21, 2007 at 12:49 am
    How did you uninstall Public Preview 1? Did you use the Add/Remove Programs control panel? If you didn’t, try that. If you did use it, apparently there are some remaining bits. You would then have to use the CS3 clean-up script. It will erase any remaining bits of Public Preview 1 (but it will also erase any other Adobe CS3 application, which you will have to reinstall).
    Adolfo Rozenfeld
  • Solie Swan
    May 21, 2007 at 1:17 am
    Thanks for quick response – I did use the uninstaller. Where do I find the cleanup script? When you say it removes all CS3 applications does that include the release version of Adobe Design Premium CS3?
  • Adolfo Rozenfeld
    May 21, 2007 at 1:24 am
    Hi, Solie.
    You can find the clean-up scripts here:
    https://www.adobe.com/support/contact/cs3clean.html
    I’m afraid yes, it will erase anything CS3, including the already released design suite applications. You can then install everything again. All of this should not be needed for the release version of AE (but removing the public preview with the uninstaller will still be necessary).
    Adolfo Rozenfeld
  • Solie Swan
    May 21, 2007 at 4:57 pm
    Thanks – that did the trick!
