Activity › Forums › Adobe After Effects › AE CS3 – Exporting multiple clips after 1 GB file size
  • AE CS3 – Exporting multiple clips after 1 GB file size
    Posted by William Sousa on December 10, 2009 at 3:23 pm
    Hi there,
    I have what I hope to be a minor problem, but one big enough to slow down my work flow.
    When I export from the render queue (.mov (animation codec)) in after effects cs3, my files get split after it reaches 1 GB in size.
    So for instance if I am exporting CLIP, in my output folder I will see:
    CLIP.mov – 1GB
    CLIP(2).mov – 1GB
    CLIP(3).mov – 250 MB
    How do I get my movies to export in one piece?
    Any help would be much appreciated 🙂
    Todd Kopriva replied 16 years, 9 months ago 3 Members · 2 Replies
  • Kevin Camp
    December 10, 2009 at 3:55 pm
    there is a an option in the output preferences (preferences>output) to segment files. uncheck that option and you should get a single file.
    note that if you happen to be using a drive formatted as fat-32, there is a file size limit to that drive structure. it’s an old format, but is still used for mac/pc compatibility. i can’t remember the limit, but i believe it is around 2gb.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Todd Kopriva
    December 11, 2009 at 4:36 am
    “The maximum file size in the FAT scheme is 2 GB, and the maximum file size in the FAT32 scheme is 4 GB”
    (from “Overflow volumes and segment settings”)
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
