Activity Forums Adobe After Effects AE-CS3 crashy
  • AE-CS3 crashy
    Posted by S Gregory on December 8, 2007 at 5:06 pm
    I’m running AE8 on a quad core with 8 gigs of ram
    This is a fresh install of everything.
    box is squeaky clean.
    But AE is completely unreliable.
    renders and ram previews consistently hang and or lock up the box
    when multi-processing is on, activity monitor shows the offender is aeselflink #8.
    I can kill that process and renders resume???
    Is this an indication that that particular ram riser or chip is bad?
    or just the tail end of the process chain?
    it’s hanging up whether multi-processing is on or off.
    I’ve tried all the tried-and-true remedies
    Ram settings, updates, re-seated cards, yada-yada
    I don’t see any recognizable pattern to this one.
    any ideas?- help.
    deadlines looming!
    S Gregory replied 18 years, 9 months ago 4 Members · 5 Replies
  • Darby Edelen
    December 8, 2007 at 11:55 pm
    [s gregory] “renders and ram previews consistently hang and or lock up the box
    when multi-processing is on, activity monitor shows the offender is aeselflink #8.”
    Generally I would tell you to disable ‘render multiple frames simultaneously’ or increase your memory cache size to reduce the number of instances AE creates. It does take some time to boot up the additional instances for multi-frame rendering.
    [s gregory] “it’s hanging up whether multi-processing is on or off.”
    But this makes me think my suggestions wouldn’t help any =)
    Do you have any other applications running with AE? What OS version are you running? Have you experienced problems with any other applications? Anything else you can tell us about your setup? OpenGL enabled/disabled? Disk Cache? RAID? Capture Card?
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Raph Nagz
    December 9, 2007 at 9:51 am
    Hello S Gregory
    Same Problem here with exactly the same system , mac pro 2 times quad intel xeon 3.0GHZ and 8GB KINGSTON RAM.
    It works on my lame old dell pc … But not on my new mac supermachine… 7
  • Steve Roberts
    December 9, 2007 at 3:39 pm
    Googling this: “after effects” CS3 crash
    … seems to lead to a few links that might help. Try this one:
    https://kb.adobe.com/selfservice/viewContent.do?externalId=kb402245&sliceId=1
  • S Gregory
    December 9, 2007 at 3:48 pm
    Which graphics card are you using?
    I’m on an ATI Radeon X1900
  • S Gregory
    Hey: Thanks for responding
    Here’s the scoop:
    Quad core – 10.4.11 – 8gigs of ram – Radeon X1900 – KONA 3 – External RAID.
    Box is a fresh build – squeaky clean.
    all apps and drivers most current versions
    All necessary firmware updated
    I removed open GL, I do broadcast and don’t like what it does to source files and fonts.
    After effects hangs up whether its running alone or with other apps open.
    Ive tried various ram allocation configs.
    most recently reduced Max Ram cache to 60%, Just now crashed.
    Crashes with disc cache on or off
    There were some conflicts upgrading some of my plug-ins…
    Tinderbox has re-engineered their sets and some legacy versions are not recognized.
    also true of Delirium.
    Forces you to manually rebuild effects chains
    I’ve built lots of systems in my time – had some bad boxes – this ones a mystery.
