Activity Forums Adobe After Effects AE CS3 Crashes on Save
  • AE CS3 Crashes on Save
    Posted by Aaron Debreczeni on September 22, 2011 at 5:06 pm
    It did’nt do it until now, but AE CS3 crashes(exits) when I click “save” the project, and it doesn’t save it.
    What can be the problem?
    Aaron Debreczeni
    Todd Kopriva replied 15 years ago 2 Members · 7 Replies
  • 7 Replies
  • Aaron Debreczeni
    September 22, 2011 at 6:18 pm
    I had h.264 .mov 1920*1080, footage in it. I’ve put them into compressor and found NTSC and PAL animation presets, so I chose NTSC. When I replaced the old footage with Alt+drag-and-drop, the footage was much smaller than the old one. I thought, it was it’s because the NTSC format is at lower resolution. I couldn’t find the PNG codecs, so I’ve chosen something that is HD and not HDV, so DVCPRO HD was my choice. Replaced the footage with it, saved, it went well. Then I did what I did before it crashed, and bamm, it crashed again. Guess I have problem with what I did, so here it is:
    I’ve got a pre-comp with 6 text layers in it. I’ve put a card wipe transition at the end of the first layer, it went well. The crash came when I put the card wipe effect on the other 5 layers, and saved.
    Is that enough information, or do you have to know more? If so, what do you need?
    Thanks for the attention.
    Aaron Debreczeni
  • Aaron Debreczeni
    September 23, 2011 at 5:06 am
    I’ve changed the footage to HD ProRes 422 footage, but AE still crashes on save.
    Aaron Debreczeni
  • Aaron Debreczeni
    September 23, 2011 at 5:10 pm
    I have no multiprocessing turned on.
    I turned off OpenGL, and it still crashed.
    I’ve reset the preferences, still crashed.
    I’ve used the footage in a previous project, and there was no problem.
    What’s strange, is that if I do anything else than copy-pasting the card wipe effect on another text layer, AE doesn’t crash when saving.
    Aaron Debreczeni
  • Aaron Debreczeni
    September 23, 2011 at 5:11 pm
    Oh, and no changes have been made on my hardware/software.
    Aaron Debreczeni
  • Aaron Debreczeni
    September 23, 2011 at 5:23 pm
    Did it this way, but AE crashed again.
    Aaron Debreczeni
  • Aaron Debreczeni
    September 23, 2011 at 6:19 pm
    Ok, thanks anyway.
    Aaron Debreczeni
  • Todd Kopriva
    September 23, 2011 at 10:03 pm
    Have you installed the After Effects CS3 (8.0.2) update? If not, then choose Help > Updates and do so. The updates fix a lot of bugs.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
