Activity › Forums › Adobe After Effects › ae crashes bad … and strange!!!
  • ae crashes bad … and strange!!!
    Posted by Pixelate on July 15, 2005 at 12:32 pm
    hi,
    just installed and have bad crashes.
    i run a system with xp, geforce 6800 gt, pentium d 820, gigabyte 955x royal board.
    i installed sp2 for xp.
    i dont know, why ae crahes.
    i tell the bugs:
    i cannot open a project over menu. then ae crashes directly. but i can open a project, by clicking on the file, then ae opens.
    i cannot drag a comp to a new comp, ae crashes.
    i cannot use every plugin, ae crashes.
    seems like a hughe problem, and maybe my system isnt set up correctly. also regcleaner cannot open.
    someone an idea what i can do?
    greetz pixelate
    Pixelate replied 21 years, 2 months ago 2 Members · 4 Replies
  • Realethan
    July 15, 2005 at 3:00 pm
    I’ve had problems similar to this in the past. Try deleting your AE preferences .ini file (or moving it to a dif folder) and restarting.
    This file is usually located here:
    C:\Documents and Settings\{USER NAME}\Application Data\Adobe\After Effects\Prefs
    (move or delete all the files in the dir.)
  • Pixelate
    July 15, 2005 at 4:23 pm
    hi,
    thanx for fast help.
    i tested it and it doesnt work.
    i uninstalled all, but same error again. could there be a problem with my hardware settings?
    greetz
    pixelate
  • Realethan
    July 15, 2005 at 9:27 pm
    Have you tried rolling your system back using XP’s “system restore”?
  • Pixelate
    July 16, 2005 at 10:32 am
    ….. i installed again sp 2 pack..
    but: i can proudly present: works fine now. i installed again latest graphic drivers. maybe there were some difficulties.
    so now my machine is running fine and smooth.
    so just a silly system problem.
    thanx alot for your helpline.
    ..::::oO…..:
    greetz
    pixelate
