AE corrupting Illustrator files?!?
Anyone had this happen or know what might cause it?
I set up a PDF compatible layered .ai file and brought it into AE for animation…all worked fine (I don’t usually use AI files, usually photoshop) until that is I did a cntrl+E command to edit a particular layer in Illustrator….Il loaded up and then gave an error saying the file was corrupted..I toggle back to AE and the same – all my morning’s work destroyed!
Luckily on this occasion I had a back up AI file that just needed some layers consolidating and renaming to re-save as previous filename. Phew. But if I didn’t have the back up..well, put it this way – my client would’ve blown steam out of his ears.
Any thoughts guys?
*Production Studio Premium CS2 / *Combustion 3 / Mocha v1
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5 monitors / Sony BVM-20G1E / DVS SDI Clipstation / Wacom Intuos 3 A4 / 110GB boot/80GB media/600GB RAID-0
