Activity › Forums › Adobe After Effects › AE comp problem
  • John Cuevas
    July 30, 2014 at 2:49 pm
    You didn’t correctly link the second picture, you need to select the picture, and then copy and paste the embed code.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Panagiwths Karapidis
    July 30, 2014 at 2:55 pm
  • Michael Szalapski
    July 30, 2014 at 3:28 pm
    I don’t understand the problem. What do you want it to look like? What is wrong with the composition?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
    July 30, 2014 at 3:37 pm
    That yellow thing (its a lemon )…..
  • Ken Teutsch
    July 30, 2014 at 3:47 pm
    It looks like the mystery is that there is a lemon in the comp window… but nothing in the timeline…?
    A mystery lemon appears in the new composition?
    July 30, 2014 at 3:59 pm
    yes, in a new project also….(the lemon is still in the fruit ninja video i made it was a video)
  • John Cuevas
    July 30, 2014 at 4:01 pm
    Try clearing all your memory. Edit>Purge>All Memory.
    Thinkck.com
    July 30, 2014 at 4:25 pm
    nothing happens…
    I noticed somthing else that is strange when i change comp colour the lemon stas everything else is fine but the lemon is still there…
    July 30, 2014 at 4:27 pm
    also if i create a comp with a vid and then make the video invisible
    i can still see it
  • Michael Szalapski
    July 30, 2014 at 5:35 pm
    What exact version (down to the decimal point) of After Effects are you using?
    – The Great Szalam
