Activity Forums Apple Final Cut Pro Legacy ae clips suddenly playing sluggish in fc6
  • ae clips suddenly playing sluggish in fc6
    Posted by Danny Perez-triana on October 23, 2008 at 3:03 pm
    hello everyone, i’m having an issue with my sequence in fc6. any clips i bring in from after effects (compressed at millions + colors) will play sluggish and stutter in my timeline.
    i’m confused cause I haven’t changed the settings and this just started happening recently. clips and sequences that were fine a week ago, now won’t play.
    i even compared the sequence in this fc on my new computer (macpro) to a fc5 sequence on my old g5 that hadn’t been upgraded and the clips played fine there.
    hmmmmm….
    any suggestions?
    ignacio
    Danny Perez-triana replied 17 years, 10 months ago 4 Members · 13 Replies
  • 13 Replies
  • Chris Poisson
    October 23, 2008 at 3:30 pm
    Sounds like the field order of the clips may be wrong, or it’s time to trash prefs.
    If you don’t need an alpha channel on them, you could try using ProRes.
    Have a wonderful day.
  • Danny Perez-triana
    October 23, 2008 at 4:13 pm
    would i be able to trash preferences without having to reinstall fc? am i just going to have rerender whatever i have in my sequences after that?
    the field dominances for the clips are either set to none, or lower (even). what does this information affect?
    thanks for the tips though,
    ignacio
    dip
    October 23, 2008 at 5:50 pm
    thanks, will do!
    ignacio
    dip
  • Chris Poisson
    October 23, 2008 at 6:15 pm
    Ignacio,
    Trashing prefs is easiest with FCP Rescue, which is a free app. No, it does not require a re-install.
    If your field dominance is set to none, then do what Dave suggested.
    October 23, 2008 at 7:52 pm
    so the resolution of my ae clips matches that of my sequence and of other clips in timeline (footage digitized into fc), and i’m still getting screwey playback with RT set to safe, high, and full. the playback was messed up when set to dynamic as well.
    i’m running a macpro with fc6 and 10gb ram. the strangest thing is that all these clips are months old and have played fine in various timelines of various projects, and now they won’t.
    i suspect it’s one setting that i’m not catching, especially since this more or less happened after i took a job where i was dealing with hdv footage and totally different settings, having to reset the scratch disk to the drive i was using.
    but everything lines up as it should.
    any help would be appreciated i’m losing time!
    ignacio
    dip
  • Chris Poisson
    October 23, 2008 at 8:51 pm
    Trash your prefs. You can do this manually or let FCP Rescue do it. It’s free and easy.
    October 24, 2008 at 12:05 am
    fcp rescue didn’t seem to do anything, if it’s just as simple as pressing the trash button?
    could it be a memory thing with external harddrives? i have 5 each partitioned into two partitions.
    i’m stumped,
    ignacio
    dip
  • David Roth weiss
    October 24, 2008 at 2:10 am
    [Ignacio Triana] “could it be a memory thing with external harddrives? i have 5 each partitioned into two partitions”
    Ignacio,
    There’s whatsoever nothing gained from partitioning, it simply adds layer upon layer to your FCP database, and wastes processing power and throughput. Partitioning makes the operating system work that much harder everytime it calls up a file ot group of files. I’m not saying that’s absolutely the source of your problem, but it’s certainly not helping your cause.
    The rule of thumb is, the fewer levels of partitions and directories FCP needs to go through, the better, and the longer you’ll be able to work on a big prpoject without it’s database becoming muddled up as well.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Chris Poisson
    October 24, 2008 at 1:49 pm
    Ignacio,
    With FCP Rescue, you must quit FCP, then hit the trash button. When you re launch FCP you should get a prompt to reset your primary scratch disk, and you will have to re-do your easy setups and preferences.
    If you do not see all this, you did not do it correctly.
    October 24, 2008 at 5:11 pm
    i quit fcp and hit trash, but did not get this prompt upon restarting, i’ll try again. thanks,
    ignacio
    dip
