Activity Forums Adobe Premiere Pro AE chroma-key won’t export from Premiere without greenscreen artifacts
  • AE chroma-key won’t export from Premiere without greenscreen artifacts
    Posted by Hannah Gbo on April 23, 2014 at 8:29 am
    Hi all! I’ve been working on a greenscreen music video that was keyed using Keylight in After Effects and then edited in Premiere. When I go to export the rendered sequence out of Premiere, I see a majority of the greenscreen pixels back in the shots. I can’t figure out why the sequence looks clean and great in my Premiere viewer, but the export simply puts that keyed-out data back in. Please help if you can! I’m unable to bounce back into After Effects for some reason (the Dynamic Link sequence shows up in AE’s project window but cannot be made into a sequence or pasted into an existing one to edit from there). Is it an issue of needing the Keylight plug-in in multiple places on my machine?
    Export attempts:
    Animation at 32-bit
    Apple ProRes at 32-bit
    PNG sequence (I’d like to avoid this as it’s giving me issues in finishing)
    Glenn Lock replied 12 years, 4 months ago 2 Members · 1 Reply
  • Glenn Lock
    May 20, 2014 at 7:19 pm
    I am having similar issues – is yours appearing in deep blacks and blues? I just ramped up my density in the key to 200 and I think it helped… frustrating though when I thought I had a very crisp green screen cut.
