Activity › Forums › Adobe After Effects › AE CC: How to invoice the Scale dialog box?
Posted by Xavier Paredes on December 13, 2018 at 3:42 pmI read elsewhere that hitting “S” and “Return” is supposed to bring up the Scale dialog box. This isn’t working for me.
I’m using AE CC (version 15).
If you know how to bring the dialog box please let me know.
Note: I know I can enter the values right under the layer. I don’t want this. I need the dialog box.
Xavier
Walter Soyka replied 7 years, 9 months ago 3 Members · 7 Replies -
Xavier Paredes
December 13, 2018 at 5:08 pmI’m using automation software so I would like to copy the scale values so I can use them in variables to compare to something and then based on that, the macro will proceed in one of two ways.
Xavier
Walter Soyka
December 13, 2018 at 6:10 pmMost of the other transforms have shortcuts for their dialogs (try Ctrl+Shift+P to see the Position dialog), but Scale and Anchor Point do not.
You will have to use the Keyboard Shortcuts editor to assign a keystroke to Layer > Transform > Scale…
Once that’s done, you can use it in your automation to get the dialog box you need.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Xavier Paredes
December 14, 2018 at 4:02 pm -
Walter Soyka
December 14, 2018 at 4:23 pmI think your hotkey combination conflicts with the shortcut for the Add/Delete Scale Keyframe command. You may need to reassign the conflict or pick a different shortcut for the Scale dialog if the conflict cannot be cleared.
Walter Soyka
Xavier Paredes
December 14, 2018 at 4:29 pmWalter, you’re a genius. That worked.
I had already completed the work yesterday (doing a bit more manual work) but for the sake of giving closure to this post and in case it helps someone else in the future I am following up.
Happy Holidays!
Xavier
Walter Soyka
December 14, 2018 at 4:30 pmThanks, Xavier, and happy holidays to you, too!
Walter Soyka
