Activity › Forums › Adobe After Effects › AE can’t launch background process anymore ?
  • AE can’t launch background process anymore ?
    Posted by Dumeyni Arnaud on December 4, 2009 at 10:59 am
    Hello Cow,
    It was working fine since quite some time with multiprocessing enabled with 3 cores.
    Then AE started slowing down the entire system when launching. A quick look at the process manager tells me that a single instance of AE is using only 130 Mb. Thats not big. I’m on CS4 9.0.2 , xp 32 bits, 4Gb RAM. When AE is launched there’s now only one instance.
    When doing some RAM previewing it works fine until i stop the previewing and AE pops : “All background process have terminated. You might need to restart application”
    So I modified the multiprocessing to use only 2 cores, but its all the same. Deleting preference didn’t helped either.
    When disabling the multiprocessing the error isn’t here anymore, but the slow start is.
    Any ideas ?
    Justin Gray replied 16 years, 10 months ago 2 Members · 1 Reply
  • Justin Gray
    December 4, 2009 at 3:08 pm
    I’m having precisely the same problem here. Irritating as hell.
    – Justin Gray
    KLTV Promotions
