Activity › Forums › Adobe After Effects › AE Bezier keyframe wobble issue
Posted by Kavon Zamanian on January 16, 2013 at 5:42 amI’m working with Trapcode Form and was keyframing a camera to move in and around the particle stream. This works well initially, but if I do more than a few simple keyframes, or try to adjust anything, I get terrible wobbling and often no response from a new keyframe until I delete the Camera layer and start over. I have set all of the keyframes I have used to linear on the spatial and temporal settings, but this hasn’t worked. From what I’ve read, that worked for everyone who had this issue, but for some reason that isn’t working for me. Any ideas? I’m on CS6 btw
Kavon Zamanian replied 13 years, 8 months ago 2 Members · 9 Replies -
Vishesh Arora
January 16, 2013 at 10:08 amKavon
I had the same problem. Though I tried creating the same effect on a PC with 16 GB which solved the issue. Mine was 8 GB. Don’t know what exactly the problem is but if you can access 16 GB of RAM, then give it a try.
Also If are okay with sharing your file, give me your file and I will try it out in my 16 GB to check whether it is because of RAM or is it a bug.
May be if you upgrade the plugin, it may work properly.
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.comDemo Reel(3D):
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Kavon Zamanian
January 16, 2013 at 11:09 pmAlright, I can send you the file man! As long as you have trapcode form installed. I have a dropbox account or i could just email you the file.
Vishesh Arora
January 17, 2013 at 10:42 amKavon
Upload your file here :
https://www.dropbox.com/home/Ae_Files
Vishesh Arora
Films RajendraBlog:
https://digieffects.wordpress.com2011 3D Demo Reel:
Kavon Zamanian
January 18, 2013 at 2:07 amYou sent me your Dropbox folder for your account but only you can view it because its under Home. You need to send me an actually share link for other users besides yourself to go to
Vishesh Arora
January 18, 2013 at 10:30 amKavon
Sorry I was in hurry.Upload your file via we transfer or send space and give me the link here only.
You can also upload it via creative cow.
Vishesh Arora
Films RajendraBlog:
Vishesh Arora
January 21, 2013 at 10:36 amKavon
I rendered your file and it worked perfectly even with my 8 GB PC.
If you want the render(RGB + Alpha), I can give it to you.
Vishesh Arora
Films RajendraBlog:
Kavon Zamanian
January 23, 2013 at 5:43 pmhmm strange. Appreciate the help man! It was an unfinished test project anyway, so I don’t need the render. I think it might have to do with faulty RAM. One of my 4GB memory sticks was bad and causing all sorts of boot issues until I took it out. I’m buying more RAM this week but I think that was probably the issue.
Kavon Zamanian
January 24, 2013 at 9:45 pmRight now I am running 4GB while I wait for another 8GB to come in the mail…I tried the project file again without a faulty RAM stick and it still has the same issue, although I wonder if it is now because of my lack of memory
