Activity Forums Zaxwerks AE 6.5 and Invig. Classic
  • AE 6.5 and Invig. Classic
    Posted by Amber :) on July 26, 2005 at 3:38 pm
    I am still having problems with Invigorator Classic. I have downloaded the latest version and I’m still ending up with the following problems:
    1. AE crashes while “invoking effect plug-in ‘3D Invigorator'”
    2. After selecting the file to ‘invigorate’, nothing shows up in either the scene pvw or the viewer window. I have to try to import the file multiple times before it works correctly.
    3. If by chance Invigorator does work like it should, I am still having problems with saving the file and then re-opening it, only to find that “missing file data” error message. My project is there, the animations are there, I can’t open options on the effects window, I can’t reload the file…pretty much all the work I did is lost.
    I don’t have any of these problems when I’m just working in After Effects. It only happens when using the Invig. I’m getting frustrated. I want to be able to take advantage of the product that we purchased. It has a lot of power, but the bugs are stressing me out right now.
    Any solutions for this? I’m at a loss….
    Amber
    Matt Rhodes replied 21 years, 2 months ago 2 Members · 4 Replies
  • Matt Rhodes
    July 26, 2005 at 5:39 pm
    Hi Amber.
    You’re using v3.1.1, correct? Are you on the Mac or the PC?
    Can you tell me what you mean by “invoking effect plug-in 3D Invigorator?”
    Do you mean that you get a crash when you apply the Invig effect to a layer?
    Also, can you send me the file you’re trying to Invigorate? I’d like to take a look.
    Thanks a lot.
    Matt Rhodes
    Zaxwerks, Inc.
  • Amber :)
    July 26, 2005 at 6:01 pm
    Hi Matt,
    You’re using v3.1.1, correct? Yes.
    Are you on the Mac or the PC? Mac dual 2.5 OS 10.3.9
    Can you tell me what you mean by “invoking effect plug-in 3D Invigorator?” Do you mean that you get a crash when you apply the Invig effect to a layer? Sorry, that was the smartmouth coming out in me. That’s correct, though. I randomly get a crash when I apply the Invig. effect to a solid layer. Also, sometimes the file imports correctly with the effect, some times it doesn’t.
    look.
    I certainly can. Just tell me where to email it.
    Thanks for your help, Matt. I appreciate it!
    Amber
  • Amber :)
    July 26, 2005 at 6:06 pm
    I should add that this was the error message that popped up when the AfterEffects crashed while trying to apply the effect to a layer.
    “After Effects has crashed while invoking effect plug-in 3D Invigorator?”
    Amber
  • Matt Rhodes
    July 26, 2005 at 9:46 pm
    Hi Amber.
    You can send files to: matt@zaxwerks.com
    m
