Activity Forums Adobe After Effects AE 6.5 and Clip duration
  • AE 6.5 and Clip duration
    Posted by Mark Perez on December 4, 2005 at 5:42 pm
    I need to import a clip to AE 6.5 and cut out some trash w/ the clone tool.
    Works well, but the issue is I have about 2 mins and AE seems to only do 5 secs on the export.
    How do I set AE to use (max duration)or the whole clip, or at least bigger portions ?
    thanks
    mark
    Enzo Tedeschi replied 20 years, 9 months ago 2 Members · 1 Reply
  • Enzo Tedeschi
    December 4, 2005 at 8:58 pm
    It sounds like you are rendering your “work area”. Two things you can do – adjust your work area in the timeline to what you want, or in your render settings, change the setting from “Work Area Only” to “Length of Comp”.
    Check the manual / help files for detailed info.
    e.
