Activity › Forums › Apple Final Cut Pro Legacy › AE 100% anim to FCP poor resolution
Posted by Jack Chute on January 3, 2011 at 11:57 amI have recently exported an iDent from AE to use within edits in FCP. I used 100% animation, 1920×1080, no field dominance and the rendered export from AE looks fine when playing it in Quicktime.
However, when I load it into FCP and render it out the resolution is greatly reduced. I am using a 1080 timeline, pro res 422, no field dominance etc.
Here are a few screen shots to show you the comparison:
Many thanks for any help you can give!
Jack Chute
Anthony Bari jr. replied 15 years, 9 months ago 6 Members · 11 Replies -
Rafael Amador
January 3, 2011 at 12:41 pmI guess that you are using Animation just because you have an Alpha Channel to export.
Try Prores 444.
In AE, render, at least, on 16b.
rafael -
Jack Chute
January 3, 2011 at 2:59 pmThanks for the reply. Just tried that and I’m getting the same jittery lines around the edges where it should be smooth.
Any other ideas?
Andy Mees
January 3, 2011 at 3:28 pmHow are you judging the quality Jack? From the Canvas window or via an external HD reference monitor? How does it look in the Viewer window as compared to the Canvas?
Paul Jay
January 3, 2011 at 4:09 pmSet Video processing to 10 bit in Timeline settings.
Then Render
Then judge at canvas 100% -
Paul Jay
January 3, 2011 at 4:10 pmField Dominance NONE = Progressive.
The i is only in the Aspect. -
Jack Chute
January 3, 2011 at 4:33 pmThanks Dave, but I already have the field dominance set to none so isn’t that a progressive timeline?
Although the preset setting says 1080i I have now changed it to custom 1080p with no field dominance (again) and we’re still not getting any better.
I’ve just tried rendering out a upper field version and tried that and it looks exactly the same.
…still stuck!
Jack Chute
January 3, 2011 at 6:03 pmThis is after an export using the “current settings” from FCP playing it on my mac full res in quicktime – still same problem. To double check, after another export I checked it in full res on my 32″ monitor…still no change!
Thanks again for your responses
Rafael Amador
January 3, 2011 at 7:07 pmJack,
Double check FCs Browser and make sure is properly interpreting the AE’s field order.
FC has very bad habits about this.
rafael -
Anthony Bari jr.
January 3, 2011 at 11:03 pmIf on your on FCP 7 use ProRes4444 with alpha. This is the new Animation codec.
hope that helps*Production*Post-Production*
Apple Certified Instructor (Final Cut Pro 7)
“Semper Fi USMC” -
Adam Taylor
January 4, 2011 at 1:12 pmlooking at your screen grab – the image on FCP has not been rendered yet. Try render that first and see if things improve!
Adam Taylor
Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
Character Options Ltd
Oldham, UKhttp://www.sculptedbliss.co.uk
