Activity › Forums › Adobe After Effects › Adviseable fps for a text based video
  • Adviseable fps for a text based video
    Posted by Syed Iqbal on May 2, 2017 at 4:58 pm
    My AE project has mp3 voice over file on one layers and hundreds of text layers for the 99% of the video synced to this VO file. Like the voice over goes quickly and each text layer shows different text on screen after every few seconds or so.
    * What should be the most advisable fps I should keep in my composition?
    * What if I want to ultimately keep the mp4 output video size as lower as possible?
    * Does fps affect the final video size?
    These questions have been in my mind for quite a long time and today I decided to ask here in this forum.
    I would really appreciate your help.
    Syed
    Bouke Vahl replied 9 years, 5 months ago 2 Members · 3 Replies
  • Syed Iqbal
    May 2, 2017 at 6:56 pm
    Hi Dave,
    Thanks a lot for your response. I would like to clarify a few points though:
    1) Video is intended for web
    2) All the text layers I have in my composition have no animation whatsoever applied to them.
    3) Client’s only concern is that the text should be sharp and readable.
    4) In my setting I have one White solid layer as background with Black text layers (using Myriad Pro font) sitting on top of BG.
    Thanks again.
    Syed
  • Syed Iqbal
    May 2, 2017 at 9:04 pm
    Thanks a lot Dave. I really appreciate these additional tips from you on BG and text color.
  • Bouke Vahl
    May 4, 2017 at 10:15 am
    [Dave LaRonde] “Yes. The more frames there are every second, the larger the file size becomes.”
    Dave,
    Not really the case with a long GOP codec like H264 or WMV.
    If the image does not change (too much), the compression is VERY effective.
    hth,
    Bouke
    http://www.videotoolshed.com
