Activity › Forums › Canon Cameras › advise on purchasining a staic dof 35mm adaptor
  • advise on purchasining a staic dof 35mm adaptor
    Posted by George Sloan on June 6, 2011 at 1:33 am
    Hi.
    I am looking for a cheap dof adapter for my canon xh a1.
    There is one on ebay for 165.00 bucks! What do you think about this for a a guy with little money.
    This DIY 35mm Depth of field adapter for all cameras with mounting thread size of 58mm – 72mm (Panasonic, Sony, Canon XL, XH, XM, XF and others). Ready to use!
    A 35mm Depth of Field (DOF) adapter is used to give video a cinematic quality often called “that film look”. So, You can record to almost any High Definition (HD, Full HD) or Standard Definition video Mini DV, HDD, DVD, SD camera and get the shallow Depth of Field that helps to separate objects from their background.
    George
    George Sloan Productions
    http://www.sloanmotion.com
    “Music Mountain” Channel 4 Windstream Cable TV
    Cannon Xh A1 1080i>FCP7>ProRes>SD DVD>Delivery on DVD to Broadcast and DVD distribution
    George Sloan replied 15 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
