Activity Forums Adobe Premiere Pro Advice required system requirements for use of laptops in editing in field with CS5.5.2 or 6 Premiere Pro
  • Advice required system requirements for use of laptops in editing in field with CS5.5.2 or 6 Premiere Pro
    Posted by Bob Dix on June 28, 2012 at 11:07 pm
    Advice is required from users of laptops for editing of Premiere Pro 5.5.2 and or 6 and Export to Blu-ray and HDV/mpeg-2 1440 x 1080 to tape in the field ?
    Freelance Imaging & Video
    AUSTRALIA
    Bob Dix replied 14 years, 2 months ago 3 Members · 4 Replies
  • Ron Pestes
    June 29, 2012 at 5:03 pm
    I use the LaCie Rugged drives in the field and they work great. Get the version that has USB 3 or esata so you have enough drive speed. I use the 1 TB size and love them. Not sure how to handle the BR problem though. I use a LaCie external burner but it requires external power so will not work as well unless you have a hotel or similar to plug into mains. Also, make sure you have as much RAM as you can get and a Nividia Cuda card is a must as well if you can.
    ronpesteshdvideo.com
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    Dell M6600
    Adobe CS6 Production Premium
  • Mike Squires
    June 29, 2012 at 6:52 pm
    I use an Asus G53SW in the field, with CS5.5, and a BMD Intensity Shuttle USB 3.0. Works great.
  • Bob Dix
    June 29, 2012 at 11:56 pm
    Thanks, Mike.
    AUSTRALIA
  • Bob Dix
    June 29, 2012 at 11:58 pm
    Yes, I am looking at the M6600 and a Blu-Ray burner installed is an option. Thanks
    AUSTRALIA
