Activity Forums Storage & Archiving advice on raid stripe and cluster size needed
  • advice on raid stripe and cluster size needed
    Posted by Mark Leger on July 11, 2013 at 6:06 pm
    building a raid 3 array with 6 seagate constellation ES.3 drives. will be used for video and photography. im a cc subscriber and use cinema 4d.
    basically whats an ideal setting for stripe and cluster sizes for this? tia
    Paul King replied 13 years, 2 months ago 3 Members · 4 Replies
  • Rainer Wirth
    July 11, 2013 at 8:50 pm
    Hi Mark,
    Raid 3 is an old system. With 6 HD’s I would recommend Raid5, if you want more protection Raid 6, but Raid 5 gives you enough redundance with just 6 drives in one array. I believe you use good reliable enterprise drives, all the same size and brand.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Mark Leger
    July 11, 2013 at 9:03 pm
    thanks for the heads up…still curious as to what i should set stripe and cluster size. btw this will be on a areca 1220
  • Rainer Wirth
    July 12, 2013 at 11:11 am
    Just follow the advice in the manual for the specific Raid level.
    Cheers
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Paul King
    July 22, 2013 at 3:30 pm
    Hi Mark
    Just leave it the default 64kb.
    you’re using it for large sequential reads so larger sizes wont make much difference. Most of these controls relate to server and database specifics.
    A 1220 is pretty old, have you already brought the controller?
