Activity › Forums › Adobe After Effects › Advice on PrePurchase PC & Specs
  • Advice on PrePurchase PC & Specs
    Posted by Gary Behrend on September 4, 2016 at 2:08 pm
    I was thinking about buying an Alienware PC model # A51R2-1766SLV made by dell. I currently have a Mac Mini and an older outdated HP use. Through a Friend I can get this new unused Alienware PC for a really really good price ($999 instead of the retail price of $1700). The Specs are Below. On a scale of 1-10 (10 being the best) how well would this PC work with After Effects, ProPremiere, & Rendering? I’ve tried to do my homework, but would just like some reassurance. I’d rather buy nice than by twice. Your help would be appreciated.
    FULL SPECIFICATIONS (not summarized)
    GENERAL
    – Manufacturer – Dell Alienware
    – Series – Area 51
    – Model Number – a51R2-1766SLV
    VIDEO
    – GPU Type – NVIDIA GeForce GTX 970
    – Video Memory – 4GB GDDR5
    – VR Ready – Yes
    – Video Connectors – 1 x HDMI
    – This PC Supports 3 Extra Wide Video cards for up to 12K. Unstoppable graphics capabilities can enable a mind-melting 11520×2160 resolution across triple Ultra HD 4K monitors (sold seperately). The new Area-51 is designed to support up to three full-length double-wide graphics cards.
    PROCESSOR – Core i7 5820K (3.3GHz)
    – CPU Core – Six-Core
    – CPU Type – Core i7
    – CPU Speed – 5820k (3.3GHz)
    – Turbo Boost Speed – Up to 3.6GHz
    – Smart Cache – 15MB
    – CPU Brand – Intel
    – Front Side Bus – QPI 0GT/s
    – CPU Socket – LGA 2011-3
    – CPUs Installed – 1
    – CPUs Supported – 1
    MEMORY
    – Total Memory – 16GB
    – Memory Speed – DDR4-2133
    – Memory Slots (Total) – 4
    – Form Factor – 288-pin DIMM
    – Maximum Memory Supported – 32GB
    OPERATING SYSTEM
    – Windows 10 Home 64-bit
    CASE & MOTHERBOARD
    – Case Orientation – Vertical
    – Motherboard Chipset – Intel X99 Express
    CPU Main Features
    – Virtualization Technology
    – Hyper-Threading Technology
    – Idle States
    – Execute Disable Bit
    – Thermal Monitoring Technologies
    – Intel 64
    – Enhanced Intel Speedstep Technology
    – Virtualization Technology for Directed I/O
    – Intel VT-x with Extended Page Tables
    (EPT)
    – Intel Identity Protection Technology
    – Intel Smart Response Technology
    – Intel AES New Instructions
    HARD DRIVE
    – HD Interface – SATA
    – HD Capacity – 2TB
    – HD RPM – 7,200 RPM
    – HD Configuration – 1 x 2TB
    SOLID STATE DRIVE
    – SSD Capacity – 128GB
    MULTIMEDIA DRIVES
    – Optical Drives Included – 1
    – Optical Drive – DVDRW
    – Optical Drive Specs – Slot-Loading Dual
    Layer DVD Burner (DVDRW, CD-RW)
    AUDIO
    – Audio System – Internal High-Definition
    – Audio via Creative Sound Core3D
    COMMUNICATIONS
    LAN
    – Gigabyte LAN
    – LAN Data Rate Speed – 10/100/1000Mbps
    WLAN
    – Intel Dual Band Wireless – AC 7260
    – Bluetooth – Bluetooth 4.0
    – Wireless Technology – 802.11ac
    MEMORY CARD READER
    – FRONT/TOP PANEL PORTS
    – USB 3.1
    – 2 x USB 3.1 (Gen 1 Type-A)
    – BACK PANEL PORTS
    – USB 2.0
    – 4 x USB 2.0 (Type-A)
    – USB 3.1
    – 4 x USB 3.1 (Gen 1 Type-A)
    – LAN RJ45 – 1
    – Audio – 5 ports
    Here is A Quick Summary Of Specifications:
    (FULL Specifications found above)
    – Intel Core i7-5820K Processor 3.3GHz
    – Microsoft Windows 10 Home 64-bit
    – 16GB DDR4-2133 RAM
    – 128GB Solid State Drive+2TB 7,200RPM
    Hard Drive
    – NVIDIA GeForce GTX 970 4GB GDDR5 VR
    Ready
    – Slot-Loading Dual Layer DVD Burner
    – Media Card Reader
    – 10/100/1000 Network
    – Intel 7260 802.11ac 2×2 Wireless
    Tudor “ted” jelescu replied 10 years ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    September 4, 2016 at 8:01 pm
    Having worked on Alienware before I can tell you that they look great, however I was disappointed by the performance – and it was not just my particular machine, there were 6 in our office. Now we have 2 Origin PC and 4 3XS ones that work great, however the price was pretty steep. I have a great machine at home however that did not break the bank, an MSI, with 32 GB RAM, i7, GTX870M. What I love most is a 3 SSD SuperRAID2 setup. That was worth all the money. This rig was under 2500 USD and it’s a workhorse. So I guess if you have the funds I would recommend to choose something else, but for the price you can get it at, it may be the machine of choice for you.
    Tudor \”Ted\” Jelescu
    Senior VFX Artist
