Activity Forums Live Events & Streaming Advice on how to broadcast live footage to a conference room.
  • Advice on how to broadcast live footage to a conference room.
    Posted by Kyle Ragaller on April 11, 2015 at 8:27 pm
    So, I am the in-house videographer guy at a large automotive assembly plant. I have been tasked with figuring out how to rig up a conference room to receive audio/video from a camera that would be out on the assembly floor capturing footage of presenters during an audit.
    The conference room is in a separate building than the assembly floor, so wiring the camera into a projector is out of the question. There is a WI-FI signal throughout the entire plant that I was considering as my way to connect the camera to the projector.
    I need advice on what devices are good that could be mounted on my camera that would transmit a signal and what device would I need at my projector to receive the signal?
    I am currently shopping around for cameras but i was looking for a prosumer sort of shoulder mounted broadcast camera, nothing fancy. I am unsure of the projector model, but it had all sorts of different I/O options, HDMI being one of them.
    Any advice on the best way to transmit A/V between buildings linked via WI-FI for a live feed?
    Thanks for the help everyone,
    Kyle.
    Steve Kownacki replied 11 years, 4 months ago 4 Members · 3 Replies
  • Thomas Leong
    April 18, 2015 at 4:25 pm
    Haven’t done this before but it sounds as if you need something like Ustream Align.
    I guess you would upload/stream the camera capture to Ustream, and on the receiving end, have a PC with a dual-output graphics card in clone mode with one output to a monitor and the second output to the projector. You may want to put a VGA switch between this second output and the projector so that you can switch on/off the send to the projector, or have the company logo up when no live stream is available – some pro switchers/seamless switchers have such a feature (rent would be cheaper, unless to be used regularly)
    Alternative to wi-fi, is direct from camera to the projector with something like the Teradek. But I think the Teradek needs line-of-sight to work well. Similar to microwave used in broadcasting sports events from the cameras in the field to the OB Van.
    best of luck!
  • Mark Suszko
    April 20, 2015 at 8:00 pm
    How good is cell phone service around the plant?
    https://www.teradek.com/pages/bond
  • Steve Kownacki
    April 22, 2015 at 8:39 pm
    teradeck has some cool things, I suggest this
    https://www.teradek.com/pages/vidiumini
    only has hdmi in put, no sdi – but it’s only $500.vv
    h.264 over wifi and create a private youtube event. A smartTV can get it directly or connect your computer to the projector.
    Steve
