Activity › Forums › Compression Techniques › ADVICE on getting 6/8 mb bit rate, stream rate 2000kbps
  • ADVICE on getting 6/8 mb bit rate, stream rate 2000kbps
    Posted by Sarah Buccaroz on February 12, 2013 at 7:50 pm
    Hi all,
    I’m trying to figure out how to use Compressor to get a file stream rate at 2000kbps and bit rate below 6-8mb/minute.
    Any advice would be gratefully received.
    best,
    Sarah
    Jeff Greenberg replied 13 years, 6 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    March 15, 2013 at 12:28 pm
    Sarah,
    Sadly, this is impossible.
    The bit rate defines the file size.
    Let’s convert 2000 kbps to how many MegaBYTEs per second (and then multiply that by 60 seconds) to get it’s result. Then let’s figure out what the number would be to hit your target.
    2000 kbps (kilo bits per second) is 2 Mbps (Megabits per second.)
    Divide this by 8 to get MegaBYTES per second (MBps)
    2/8 = .25 MBps
    So, each second takes up .25 MegaBytes – or 4 seconds = 1 MegaByte.
    60 seconds takes up 15MB.
    If we decrease the original data rate in 1/2, we’ll get what you want.
    So, if you drop the data rate to 1000kbps, you’ll get files around 6-8 MegaBytes per minute.
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
