Activity Forums Maxon Cinema 4D Advice on a new PC build please
  • Advice on a new PC build please
    Posted by Neil Moore on October 23, 2014 at 7:59 am
    Hi people I am looking for some advice on building a new windows based PC as my old Dell XPS400 has just about had it.
    I already have a 2 year old AMD built system but I use this purely for design work(Adobe AE, C4D, Autodesk etc) and don’t have it connected to the net.
    So what I wanted to do was build another PC that can do general surfing of net and design work etc but also help a lot with net rendering along side my existing AMD PC when needed.
    I will not be using the new build for gaming just design and surfing net.
    I am planning in the future to use the Octane render so GPU is also important factor on this build.
    So before I get to far into this and I know people will cringe a little but I think I want to stick with an AMD build as the processor is way cheaper and is more in line with my budget of between £500 – £650.
    I have also read that mixing AMD and Intel for net rendering can cause problems.
    I’m going to re-use some of the parts from the old Dell such as SSD’s, DVD drive, keyboard etc.
    As my budget is tight I will be adding just enough RAM, maybe 8GB then add to this later down the line when I have a bit more cash so this way I can put more money into the main parts of the build.
    Any help on a system build would be much appreciated,
    Thanks people.
    Neil Moore replied 11 years, 10 months ago 1 Member · 2 Replies
  • Neil Moore
    October 23, 2014 at 2:18 pm
    OK so far I have the following:
    990FX R2.0 AMD Asus Sabertooth AM3+ ATX Motherboard
    CoolerMaster N-Series N200 USB 3.0 Micro-ATX Case
    Corsair H80i Hydro Series Extreme Performance CPU Cooling
    Corsair 750W CX Builder Series 80PLUS Bronze PSU
    AMD FX-9590 5GHz Max Turbo AM3+ Black Edition 8-Core 8MB OEM
    RAM? dont know what type to get yet but want it to run efficeintly with processor. Need 8GB to start.
    GPU? Need advice on this – totally confused
    Thats £459 so far
  • Neil Moore
    October 23, 2014 at 2:44 pm
    I think maybe I will have to drop the GPU card for Octane render as this will require quite a beefy card which I cannot afford.
    So need a GPU that is good for C4D, Adobe AE, 3DS Max etc to go with the above.
    Cheers
