Activity › Forums › Adobe Premiere Pro › Advice Needed! – Sound Dropping Out on Old AND New System
Matt Ellsworth replied 13 years, 7 months ago 9 Members · 33 Replies
Stephen Cone
May 23, 2012 at 4:29 amRyan,
Yep. Sounds like we’re in the same boat. Today, just to experiment, I created a brand new project on this ridiculously overpowered new system, pulled in a clip and a .wav file, played them just fine separately and then watched the audio die away about 5 seconds in both the timeline and source monitor.
It’s so frustrating. I’ve got a feature to cut and I may have just put down $2200 on a new system for nothing. Maybe there’s a hero out there somewhere…
Good luck, and let me know if you hear anything.
Stephen Cone
cone.stephen@gmail.com -
Ryan Patch
May 23, 2012 at 4:40 amWhat drive are you playing these files off of? Are they on the same drive? What compression is the Scarlet footage?
Stephen Cone
May 23, 2012 at 4:56 amEverything’s on two externals. Reading the Scarlet footage natively at 4K HD 3840 x 2160.
Ryan Patch
May 23, 2012 at 11:01 amOver what protocall (USB, FW800, etc) is there a raid involved, and what soeed are the drives?
Also, where are your media cache files setup to be stored!?
Paul Neumann
May 23, 2012 at 1:09 pmHow’s the level on that clip? There’s a “mute clipped audio” setting that’s given me fits before.
Ryan Patch
May 23, 2012 at 5:37 pmThat’s interesting. I’ve never heard of that. Where is it located?
Nick Brown
May 24, 2012 at 5:28 pmI had the ATI 4850 in my CS4 System and it worked very well. As soon as I updated to CS5.5 my system had all kinds of stability issues and wonky behavior.
One solution fixed them all. I replaced the ATI went with a Nvidia 560ti with 384 Cuda cores and OMG it is now a fast stable system. Rips through stuff in realtime bigtime. You’ll need to add the card to the text file in adobe/Premiere Pro CS5.5/Supported Cuda Cards.
Ryan Patch
May 24, 2012 at 5:37 pmSteven –
I have been playing around with this audio issue, and I have found that when I decrease the volume a bit of channels in the audio mixer that my audio drops out less, possibly related to this “mute clipped audio” feature that I don’t know where to turn off. This might be a placebo, though.
Do you have one track with really loud audio?
Nick Brown
May 24, 2012 at 5:44 pmWith the ATI, my audio was messed up and constant crashes. I spent hours trying to fix the issues and gave up. Spend $200 and get a video card that works. My guess is the ATI’s audio drivers were the problem.
Seriously you will be amazed at what the Mercury engine does and will not regret pitching the 4850 int your e-waste bin or selling it on eBay for $20.
Ryan Patch
May 24, 2012 at 5:49 pmNick –
I am running a Quadro 4000 and getting this issue. I don’t think it’s the video card.
