Activity Forums Live Events & Streaming Advice for Sending Video to Multiple Screens at Tradeshow
  • Advice for Sending Video to Multiple Screens at Tradeshow
    Posted by Chas Smith on October 13, 2008 at 3:37 pm
    I produce short videos for corporate clients. I’ve been asked to find a fail-proof method to switch video between a laptop Powerpoint and DVD output to 3 or 4 large screen monitors at a tradeshow.
    I was thinking the operator could simply loop the signal through all the monitors and use the menu remote to switch input on a main monitor. This would be simple but I’m not sure if it’s “user friendly”. 😉 soooo I was wondering if there’s a simple interface out there like an “A/B Switch” to let the user manually switch between the laptop & DVD outputs? (I’m not much of a techie…that’s why I’m asking here.)
    Also… because of driving multiple monitors…. will the “signal loop” work or do I need to consider signal amplification? The monitors will be on a corner booth that will be probably 20′ & 20′ so we’re not talking a long patch cable-wise. Any and all suggestions are appreciated.
    Chaz
    Chas Smith replied 17 years, 9 months ago 2 Members · 2 Replies
  • Walter Soyka
    October 13, 2008 at 8:21 pm
    Hi Chaz,
    First, I’d make sure the monitors accept VGA input. Next, I’d rent a hi-res switcher like a Folsom Presentation Pro (which will accept both your VGA from the laptop and composite, Y/C, or component from the DVD player) and outputs a VGA signal. Also rent a VGA distribution amplifier (which is essentially a powered splitter). Run one cable from the DA to each monitor.
    This will be rock-solid.
    Walter Soyka
    Keen Live, Inc.
    Digital Media Design & Technology
  • Chas Smith
    October 14, 2008 at 5:03 pm
    Thanks for the info, Walter!
