Activity › Forums › Apple Final Cut Pro Legacy › advice after effects to final cut
  • advice after effects to final cut
    Posted by Marise Nazzaro on July 6, 2010 at 7:55 pm
    I am new to after effects and when I import files that have been converted to .mov from after effects, I get the warning – dropped frames message. I don’t have the drop down in final cut to turn off unlimited rt, I am not sure how to lower my compression data rate and I know my system is fine. Does anyone have any suggestions?
    Marise Nazzaro replied 16 years, 2 months ago 2 Members · 2 Replies
  • Todd Gillespie
    July 7, 2010 at 5:08 pm
    It sounds like After Effects is exporting out using the Animation codec?
    You’ll need to check to make sure the codec that you are editing with is the same codec you render out of After Effects.
    Good Luck,
    Todd at UCSB
    Television Production
  • Marise Nazzaro
    July 7, 2010 at 5:59 pm
    Thanks Todd. It turned out I had the wrong format size. I was using 1440×1280 and for whatever reason it worked 1280×720? Go figure?
