Activity › Forums › Adobe After Effects Expressions › [ADVICE] After Effects Time Expression changes the Rotation position of object!
  • [ADVICE] After Effects Time Expression changes the Rotation position of object!
    Posted by Sonia Li on August 11, 2017 at 7:12 pm
    I’m working in After Effects and come across something that I’ve been Googling to no avail. Should be fairly simple but having trouble figuring it out.
    Basically, when I use the time expression (time*500) in Rotation, the expression sets my object Rotation position to 0. (original position of object is not 0) This changes the composition of my object. How do I use the time expression without having it change my composition??
    Thanks so much in advance!!
    Andrei Popa replied 9 years, 1 month ago 2 Members · 3 Replies
  • Andrei Popa
    August 11, 2017 at 7:52 pm
    Try this
    time*500+value
    Andrei
  • Sonia Li
    August 11, 2017 at 8:08 pm
    Thanks so much Andrei! Works like a charm ☺
  • Andrei Popa
    August 12, 2017 at 10:48 am
    You are welcome. Glad i could help.
    Andrei
