Activity Forums Storage & Archiving advantage disadvantage using 400 Gig Sata Drives in San
  • advantage disadvantage using 400 Gig Sata Drives in San
    Posted by Richard Milner on July 3, 2005 at 7:18 pm
    I’ve been told that while 400 gig drives offer more capacity, that there are performance issues when you really start taxing a san with more than 5 or 6 users.
    The performance of 250 Gig drives are supposed to be better because of the faster time that they can access data.
    Does the Xsan still use only 250 Gig Drives?
    John Mcclary replied 21 years, 1 month ago 3 Members · 4 Replies
  • Floh Peters
    July 5, 2005 at 3:07 pm
    [Richard Milner] “Does the Xsan still use only 250 Gig Drives?”
    The XServe RAID is also available with 400GB drives, but it does not use SATA drives, only the older and slower Ultra ATA standard.
  • Richard Milner
    July 10, 2005 at 4:19 pm
    Do you know how many 25mbit streams can be supported on an Xsan with 400 GB drives a s compaed to 250 GB drives?
  • Floh Peters
    July 11, 2005 at 8:34 am
    Hereare some Apple numbers about that. Probably not exactly what you
  • John Mcclary
    July 12, 2005 at 6:04 pm
    Six DV clients is not a lot of bandwidth for a SAN. Our Terrablock server shows no slowdown for 5-6 clients and support up to 12 dual-stream clients at DV resolutions.
    John McClary
