Activity › Forums › Adobe After Effects › Advanced Line dissolves
Posted by Ash Carter on January 30, 2013 at 11:35 pmHi, i’ve been trying to figure out what plug in used here to make this line dissolve effect. He first has a line in between 2 points which may be the beam effect. Then the line dissolves like smoke. Link below
https://www.youtube.com/watch?feature=player_detailpage&v=9GW_5Nkx8qE#t=95s
Much appreciated!
Vishesh Arora replied 13 years, 7 months ago 2 Members · 7 Replies -
Vishesh Arora
January 31, 2013 at 9:12 amAsh
Seems to be Trapcode Particular.
Here is a Tut with similar look :
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.com2011 3D Demo Reel:
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Ash Carter
February 7, 2013 at 12:06 amAfter looking into this further i have found that it is the Plexus plugin. Really cool plug in, however there is still the issue of the lines and shapes dissolving like smoke which i can’t figure out yet. THis has been a quest!
Vishesh Arora
February 7, 2013 at 8:03 amAfter looking into this further i have found that it is the Plexus plugin.
At first I had the same though about it but the last dissolving effect changed my perception. Don’t know whether it is possible to get the smoky effect from plexus.
Vishesh Arora
Films RajendraBlog:
Ash Carter
February 8, 2013 at 3:36 amyeh right. i think you are right. do you know of any cool smokey dissolve plugins or effects similar to that one?
Vishesh Arora
February 8, 2013 at 7:19 amI gave you the link in earlier post which is somewhat similar to this.
Though some manipulation in parameters is needed. I am quite busy these days. When I will get time I will try to create the same look and will upload the project file for you. Till then you can search on web on how to create smoky feel with plexus.
Vishesh Arora
Films RajendraBlog:
