Activity › Forums › Avid Media Composer › adrenaline paint effect
  • adrenaline paint effect
    Posted by Jack Entonces on February 12, 2008 at 6:29 pm
    I’m working on the adrenaline.
    And I need to circle a face in the foreground of the video,
    to make it stand out.
    Using the paint effect,
    I draw a circle around the face, then from the drop down menu I
    select “outline” to make a border around the circle.
    What i want to know is, is there some way to increase the
    width of the outline border around the circle?
    Another question:
    if I want to highlight the face,
    i select “highlight” from the drop down menu.
    But how do i put a border around the circle highlight?
    thanks!
    Jack E
    Randy Pfeiffer replied 18 years, 7 months ago 2 Members · 1 Reply
  • Randy Pfeiffer
    February 15, 2008 at 7:01 pm
    Hi, Jack
    My method is to use “paint effect” to create the circle (white or what-ever color you choose) Mode set to solid. – I usually set “feathering” to 2 to 4 to soften the edges…
    Then control-c (copy on the pc)… control-v (paste on the pc)… Grab each of the control points (of the second circle) to size this circle smaller then the first circle. Mode set to erase…
    HTH,
    Randy
