Activity Forums Avid Media Composer Adrenaline effects palatte
  • Adrenaline effects palatte
    Posted by Jack Entonces on June 26, 2007 at 8:35 am
    Hello,
    I have the Avid Xpress DV 3.0 on a windows machine.
    The effects that come with it are pretty basic, no 3D Warp effects.
    At work, they got the Adrenalines, which has a pretty sweet effects palatte, including 3D Warps.
    I’d like to know if it is possible to purchase the same effects that are on the Adrenaline effects palatte so that I can put them in my
    Xpress DV effects palatte.
    Is there a low-end Adrenaline for the amateur or semi-pro editors who edit at home?
    Grinner Hester replied 19 years, 3 months ago 4 Members · 4 Replies
  • Accountfrozen_needs_realname
    June 26, 2007 at 6:43 pm
    The answer for you would probably be Avid Xpress Pro or Media Composer software-only version. Neither of these is what you’d call “cheap”, but they have the solutions you are looking for.
    Keep in mind these packages come with VERY specific hardware requirements too. There’s not a really an in-between step between Xpress DV and these packages. You have to be ready to pony up.
    Jon
    _______________
    Lack of preparation or organization on your part does not constitute an emergency on my part.
  • Grinner Hester
    June 26, 2007 at 10:04 pm
    [jack entonces] “Is there a low-end Adrenaline for the amateur or semi-pro editors who edit at home?”
    still all thats available, imo.
    Unfortuaatly, it costs 45k.
    To answer your question, no but you can get some great plugin effects. Scope out Genarts Sapphire and for that matter, surf the rest of the suprted AVX plugins listed on Avid’s site.
  • John Pale
    June 26, 2007 at 10:34 pm
    [jack entonces] “s there a low-end Adrenaline for the amateur or semi-pro editors who edit at home?
    You might want to check out some of the software/hardware options at a place called apple.com….word is they have a scalable editing solution that a few people seem to like
  • Grinner Hester
    June 26, 2007 at 11:05 pm
